Any tricks for checking Float level?
Old Jan 26, 2010 | 09:36 PM
pablohoney's Avatar
Default Any tricks for checking Float level?
I know how basic this is and I can do it fine with other bikes but the four carbs is making it difficult. You check the height with the needle just being touched by the tong right? Is there an easier way than just holding the float and looking at it from the side, then measuring it? There is so much stuff in the way, it makes it hard. Any tricks? Thanks
Old Jan 27, 2010 | 07:24 AM
tomttt's Avatar
Pablo, I just did my this weekend, by the book. It was very easy. The method was to let the floats hang then slowly rotate the carbs until the float moves toward closing, but only until the the needle seats, but not to compress the spring in the needle. then just measure from the carb base to the bottom of the float. I used a caliper set to the .54" ,that is what mine were to be set to.
Problem with mine is that they have no way to adjust them. Luckily they were all correct.
Hope this helps.
Old Jan 27, 2010 | 10:04 AM
pablohoney's Avatar
Thanks for the help guys, should be no problem now.
the600
F2 Tech
Jun 18, 2013 06:34 PM
gator215
Apr 10, 2010 08:00 AM
raylee
Mar 12, 2010 08:08 AM
cumminsboy3
Jun 9, 2009 12:10 AM
Budji
Nov 2, 2008 02:13 PM
