Another water pump question
Old 07-31-2009, 12:22 PM
teknoanimal's Avatar
Registered Users
Default Another water pump question
I was on my way to work and i accelerated hard and fluid came up through the hole where the triple tree goes through. my right shin was soaked in fluid. I am assuming its the water pump because i had a car that the pump went out in it just dumped fluid. i went back to my apartment and apparently it was leaking when i left but i didnt notice. it didnt over heat or anything, i might have got back home in time. So I guess my question is, how do i tell the pump is bad? thanks for any help.
Old 07-31-2009, 12:40 PM
TimBucTwo's Avatar
What is the temp. reading on the gauge? Is it over heating?
I would tend to think it is the radiator cap leaking.
Old 07-31-2009, 01:38 PM
Shadow's Avatar
It's not the pump, I think.........
Check your cap and the 3 way plastic connector in your hoses under the thermostat......
Old 07-31-2009, 02:49 PM
michealparks's Avatar
RIP "The Baron of Bronson"
Ditto.
My 3 way tee had a hairline fracture in it and it only leaked at operating temp. Real easy fix.
Old 07-31-2009, 05:48 PM
Registered Users
man that would be so awesome if thats all it was , just to be sure is this the part? http://www.bikebandit.com/houseofmot.../m2022sch13753 #20 under cooling>radiator? Thanks for the help.
Old 07-31-2009, 05:50 PM
Registered Users
oh yeah and the temp didnt seem like the guage moved at all in about 10-15 min from when i started to noticing the leak to getting home. but it definitely was warm cause steam came off the engine.
Old 07-31-2009, 11:45 PM
Shadow's Avatar
Old 08-01-2009, 12:47 AM
Registered Users
hehe you came up with a top end gasket set for part #20?
You guys were on the money with that tri way part being the culprit. it was broken where it went underneath the tank. And while i was wrestling to get the hose separated, it broke again. go figure. I was crapping bricks because i did not want to spend a couple hundred on a new pump. 25 on a new part is much better. Thanks for the help guys.
Old 08-01-2009, 05:30 PM
Glad we nailed it. Mine broke in the same spot. My previous owner spray painted my silver so I actually thought it was metal untill I put my hands on it. haha. When I pulled it off one of the other ones broke off too. Your temp probably wasn't coming up because your temp sensor wasn't getting wet! lol.
Glad to help!
Old 08-01-2009, 07:36 PM
malbojah's Avatar
I've had this happen to me on the side of a highway. When you run low enough on coolant, your temp gauge should spike when you get on the gas, and come back down as you slow down.
Side note: Walmart sells a stuff called Liquid Steel (or something "steel" in a plastic tube). Works great when your in their parking lot to seal the 3 way tee to the coolant pipes
Quick Reply: Another water pump question
