Alternator chain tensioner
Old Jun 15, 2024 | 05:59 AM
ThomasPlooij's Avatar
Default Alternator chain tensioner
Hi all!
This is my first thread on this page as I'm commiting to the task of replacing the alternator chain tensioner as I can't stand the rattle. I've already replaced the camchain and modified the tensioner but this wasn't the source of the rattle... On another thread I read you can check if it's the alternator chain causing the problem by taking the alternator cover of and see if the shaft can be turned by hand, which it shouldn't if there would be tension on it.
So my question is if it's enough to just replace the tensioner (as I read this often fails) and leave the chain itself alone? This would be a lot less work as the alternator can stay in place as well as the camchain and shafts.
And would it be possible to leave the engine in the bike and just take of the bottom crank case? I know I still would have to remove a lot of parts to get to the three upper bolts which hold the halves together.
Any advice would me much appreciated as I've never undertaken as big of a engine job before
Cheers,
Thomas
Old Jul 30, 2024 | 01:55 PM
walivabuc's Avatar
Old Jul 30, 2024 | 02:01 PM
walivabuc's Avatar
Mettiti l'anima in pace. Per sostituire il tenditore della catena dell'alternatore( se lo trovi) č necessario smontare il motore, girarlo sottosopra, smontare la metā del motore e sostituire il pezzo difettoso. Ci sono dei filmati su youtube che ti fanno vedere come fare. Non si sono altre soluzioni. Anche io le ho provate tutte. Per esasperazione ero arrivato al punto di tagliare a meta quello vecchio montato e sostituire la metā nuova saldandola ma poi ho desistito. Sono solo tre bulloni che vincolano il tenditore, due sono accessibili, il terzo č posto sopra gli ingranaggi del cambio e non c'č spazio per smontarlo. Amen
ThomasPlooij
How To's
Jun 15, 2024 05:30 AM
CycleMadness
How To's
Feb 27, 2023 07:20 PM
Lynch
Dec 5, 2022 07:13 AM
walivabuc
Jan 29, 2020 01:11 PM
walivabuc
Jan 10, 2020 11:57 AM
