Airbox
Old Feb 28, 2008 | 10:07 PM
lilbear777's Avatar
Default Airbox
Is that thing from hell or what!!! ? Looking for something better, any idea's ?
Old Feb 28, 2008 | 11:08 PM
Shadow's Avatar
Default RE: Airbox
CBR's are designed to run with "neutral" airflow, that is they work best with "still" air going into the carbs. Best option is fit a single K&N filter in the box to improve airflow. If you fit Cone-type airfilters to each carb, the bike won't perform as well. K&N filter's good for the life of the bike, and can easily be washed and refitted. It does make a difference........mainly on throttle response.
Old Mar 2, 2008 | 05:41 PM
lilbear777's Avatar
Default RE: Airbox
Thanks for the info. I just put a k&n filter in it and cleaned the carbs. I had doubts about room for separate filters plus theywould cost alot more than the canister filter. Just curious : ]
Old Mar 2, 2008 | 07:00 PM
Roger's Avatar
Default RE: Airbox
Wouldn'ta mixture adjustment be necessary if we change the air flow rate with the K&N filter, or do I have that wrong?
Thanks.
Old Mar 2, 2008 | 11:51 PM
Shadow's Avatar
Default RE: Airbox
The bike is overjetted as standard, and changing mixtures shouldn't be necessary. My bike has aftermarket pipes on it with 2" s/s collector pipes, and even then the jetting is fine...still runs a bit rich at anything under 125MPH which is fine with me.
Treesquid
CBR1000F Wanted / Swap
Dec 2, 2009 11:13 PM
hypeshipe
Jan 20, 2009 07:22 PM
chpanther69
Apr 25, 2007 07:57 PM
hawkti
Jun 21, 2006 06:41 AM
