Adjustable Brake and clutch levers?
Old Aug 17, 2008 | 10:30 PM
Stray Cat's Avatar
Default Adjustable Brake and clutch levers?
Anyone know where I can find them for the 'cane? Will later model VFR or Blackbird levers work? I see a lot for the RR bikes but nothing for our bikes.
Old Aug 18, 2008 | 12:15 AM
Shadow's Avatar
Default RE: Adjustable Brake and clutch levers?
My 90 model has adjustable levers..........?
Also looh at Pazzo levers - expensive but very good.
Old Aug 18, 2008 | 06:52 AM
boink1079's Avatar
Hi Shadow,
Is there a way to adjust the levers so that the clutch engages a bit sooner? I like to use two fingers on the clutch, but my remianing fingers cop a bit of crushing.
Old Aug 18, 2008 | 07:08 AM
Shadow's Avatar
Not with the standard levers, to my knowledge..... Clutch is quite fierce, maybe need to use Pazzo levers which are easier on the hands.
Old Aug 18, 2008 | 10:51 AM
Stray Cat's Avatar
ORIGINAL: Shadow1
The brake is adjustable, but not the clutch. I want both!
I saw the Pazzo, but they don't have a listing for the CBR1000f.
Old Aug 18, 2008 | 11:21 AM
Shadow's Avatar
Check previous posts from FLOGGER on this - he found part numbers for the 1000F for Pazzo levers.
Old Aug 18, 2008 | 03:15 PM
tallenuf's Avatar
You can save some cash on expensive levers and buy a pair of these instead:
Old Aug 19, 2008 | 06:50 PM
Stray Cat's Avatar
I don't have an issue with the effort on the clutch or the brake. I would like to replace the rattling POS stock clutch lever, and if I'm going to do that, I'd like to put on an adjustable unit. And to keep things symetrical, I'd get the same for the brake side.
Old Aug 19, 2008 | 07:54 PM
Shadow's Avatar
Firstly why is your clutch lever rattling ?
Secondly, your original levers aren't symmetrical - brake is a good bit shorter than clutch.....
Old Aug 19, 2008 | 08:09 PM
weekendrider's Avatar
I have two 88cbrs one has adjustable levers the other not. The one that does not is a jap import
