Absolutely Sick to my Stomach!
after making the video, that was the last of the noise. I took it for a cruise around the block and, the valves sound alot noisier then I remember. maybe I need to do that valve adjustment afterall.. im lost on what to do. I cant even hear the faint sound of it I heard before. I hate to just start stripping it down, if I cant reproduce the sound/issue. Also it seems after the bike is warmed up, its almost impossible to start back up.. has to be valves eh?
Oh yea btw, thanks for all the input.. makes me feel better to know im not dealing with this, totally alone. I have no friends that have bikes, so without CBRF id be all on my own to figure out every little thing that comes up.
Guest
Posts: n/a
No chit ...? you took her for a run like that !! ....wow , guttys move Ebinz ...
Gee , I think I would have removed at least the rocker cover and alternator cover to check for anything obvious first ...
Mate ...did you check the oil for any signs of anything strange? ....water ect ?
and yes you are dead right , you are never alone with this place behind you ....
If she is hard to start after being warmed up , it could be a few things ...and more than likely carb related rather than valves , although checking them again may help ...
Yep, I'd certainly have a good look at the oil/antifreeze for sure, and recheck your valves. Noisy valves are ones on the loose side. If they are in spec, tho, they are fine. I've never met a honda without a little valvetrain noise. Plus, if you happened to take that little spin without a helmet on, the motor is gonna sound a lot louder than with a helmet...
The hard starting is probably carb related, tho, like classic said.
I wonder if maybe you're getting excess fuel in one of your cylinders? Hmm..
I did at least check the oil.. Ive blew a head gasket on a pontiac one time, so I do know how to recognize that "chocolate milk" look or oil in water, and no from what I can tell it looks clean, I've taken a picture and uploaded it to the site. I do notice a strong 'gas' smell to the oil. I think I read on Dans Motorcycle repair course he states gas smelling oil is a result of improper float levels correct? so it looks like the carbs are coming back off, no doubt. This weekend I am going to pull the rocker cover and try some ideas u guys gave me to see if I can pinpoint something.
Guest
Posts: n/a
Yer , petrol in the oil would at least explain the liquid you saw in that exhaust ... and you may be luck as petrol in the oilsd may also cause the clutch to howl its head off too ...
Maybe the tank emptied quite a bit into your engine while she was sitting ...internal flooding will do that ...
Gee I hope it is all that was wrong .... you would be getting off lightly if it is just that ...a quick carb check ..
Which ever pipe was wet , I would be getting straight to that carb for sure ..
anyways ...drop that oil before you re start her if it stinks of gas ...
