95 cbr 1kf rear pad replacement - compressing caliper
Old Apr 7, 2010 | 04:57 PM
WhiteHawk's Avatar
Default 95 cbr 1kf rear pad replacement - compressing caliper
What is the best way to compress the rear caliper when swapping out rear pads? This is for a 1995 CBR 1000F w/ linked brakes
Thanks in advance!
Old Apr 7, 2010 | 10:07 PM
malbojah's Avatar
biggest blade screwdriver that you have. Pry in there, then leverage until the pistons compress back.
Old Apr 8, 2010 | 04:41 AM
Aussie Johnno's Avatar
Ride of the Year ... Just Ask The Boys
When i changed my brake pads out i used the old pad against the caliper and a clamp to SLOWLEY compress the piston back in, no problems at all.
But my bike is NOT the linked brake type, so i am not sure if will work the same, it should, that's why i say SLOWLEY
Aussie Johnno
Old Apr 8, 2010 | 04:09 PM
KenG's Avatar
Senior Member & can cook minute rice in 58sec
yip,, big screwdriver,,,, very,slowly
Old Apr 8, 2010 | 04:42 PM
pacojoseph's Avatar
or, expandable pliers.
Old Apr 9, 2010 | 10:19 AM
dietDrThunder's Avatar
Be sure to clean the exposed part of the piston completely before you push them back in. The only thing that retracts the brake pistons is the tiny ridge on the seals. It doesn't take much to overwhelm that, and make the brakes drag.
Old Apr 13, 2010 | 10:13 AM
WhiteHawk's Avatar
I got the new pads on, they work excellent. I also did a hydraulic system flush (brake and clutch) and while I was bleeding the rear caliper, I put tubes on both bleeder-screws and loosened them. I was then able to easily compress the caliper to install the new pads =)
nrmskate
F4i - Wanted
Mar 12, 2012 09:23 AM
ian7321
F4i - Wanted
Apr 1, 2011 11:59 AM
hawkwind
Jun 10, 2010 12:37 PM
lawdog4545
Feb 24, 2010 07:25 PM
spdbump36
May 8, 2008 09:11 PM
