'88 CBR1000F, Horrible Rattling!
Old 09-18-2008, 06:03 PM
Napalm1000's Avatar
Default '88 CBR1000F, Horrible Rattling!
Anyone Familiar with a rattle that comes and goes around the Radiator area?
I simply turn the front wheel and it goes away, but comes back when riding.
Curious if anyone has experienced this issue, I have not investigated at this point, but plan to soon.
Thanks All!
Old 09-18-2008, 06:59 PM
Napalm1000's Avatar
Default RE: '88 CBR1000F, Horrible Rattling!
Thanks for the Reply, I kinda thought it was the Fan Blade, but it Rarely comes on.
Sounds like a Plastic, non-metallic rattle!
Your Descriptions were great by the way!
Old 09-18-2008, 07:47 PM
DragonCBR's Avatar
ARRRGH front wheel bearings...change them as soon as psossible!
Old 09-18-2008, 07:57 PM
pacojoseph's Avatar
Not so fast. Does it rattle at all when your not moving- if so shouldn't be wheel bearings.Sounds more to me like you've just got a loose bolt somewhere.
Old 09-18-2008, 08:35 PM
na there has been a lot of complaints with this rattle noise you all speak of its been on this form since i joined up almost 2 years ago.. there is a tensioner that has to do with adjusting something im sure if you look in this form it will come up like i said it has been an on going thing in this form, butthere is no way to fix this all that does by making it tighter or losser makes the rattle louder or faster.. Its a honda thing nothing to worry about i have owned my 96 cane for 2 years not and hadnt had many problems with it and there all almost the same buile from 88 on up.. And for a tire bearing all you have to do is get the wheel off the ground a little bit wether it be a lift or crank ties and lift it up by a tree and move the tire side to side if its not loose then dont worry there fine but if the tire jumps .22mm side to side its time for new bearings and they usually go out depending how you ride (if ur like me and ride during the summer months only) then 3-4 years as im told good luck!!
Old 09-18-2008, 08:51 PM
Default RE: RE'88 CBR1000F, Horrible Rattling!
HAHA im telling you this has been brought up a lot and ppl have had the same noise and explanation and played with it said that was the problem.. wont hurt to try and doesnt hurt to check the wheel bearings ither or anything eles for that matter lol
Quick Reply: '88 CBR1000F, Horrible Rattling!
