1988 hurricane clutch....
Old Aug 19, 2009 | 05:30 PM
JWChadwick's Avatar
Unhappy 1988 hurricane clutch....
So I got this bike a few weeks back, and have been tinkering a little with it. It needs help. Here is my current issue.
I tore the slave cylinder apart, flowed new fluid in at the top, and out at the bottom. put slave cylinder back together with old rubber( I know, I know). And reassembled it. When I squeeze the clutch, it has pressure on it, but the clutch does not disengage. BUT, The slave cylinder actually moves away from the engine. I mean, it flexes the case.
Obviously, I have to take the actual clutch apart, but this seems very strange. I am not sure what to expect inside there.
What is a good quality clutch replacement online?
Where can I get replacement seals online?
Any chance the clutch rod is hanging inside?
Old Aug 19, 2009 | 07:48 PM
kilgoretrout's Avatar
Administrator - Retired
So was the clutch not working before you tore the slave apart?
If it was working fine before, my guess is that you re-installed something wrong in the slave? Internal leak? That's kinda strange, though.
Have you downloaded a shop manual yet? That would be a good place to start if you haven't. It is located here (Courtesy of Trips): CBR Service Manual PDF
As far as a clutch disk kit, you can get them anywhere. Bike bandit has ebc kits for about $75, and they are all over fleabay, too.
However, I'd guess that you'll have to tear it apart and find out what's binding first.
Old Aug 19, 2009 | 09:43 PM
JWChadwick's Avatar
no it wasn't working to start, i figured trash in the line, or air. but it is not leaking into the case. When it is out of the bike(slave) and i pull the handle, it pushes the piston out a little, and if i squeeze real hard, i can get the fluid to go back to the resorvoir. Thanks for the shop manual link. I think the slave works properly, and it is after that in the full system. I can't imagine clutch or basket failure, I am thinking pushrod a little more now.
I have not ridden this bike, and have not seen it run. The clutch felt empty before, but had fluid in it, and upon proper drain and bleed, I got motion. Just want to kick the bike around the block to see what all i need to do before she is worthy.
Thanks for the relocate buddy!
Profitness
May 8, 2010 03:41 AM
APOSTO
Jun 17, 2009 06:26 AM
camaro_jake
Jun 20, 2008 04:40 PM
