600 Modifications This section is specifically for questions and advice pertaining to mods of the older 600 models.
Velocity stacks on a F3 ????
Old Feb 11, 2008 | 04:36 AM
VALKYIE's Avatar
Default Velocity stacks on a F3 ????
I was sitting at work today reading a sportbike mag and I said to myself is it possible to put velocity stacks on a F3 similar to the ride by wire system of the new R1 and R6. So I am going to do some research to see if its possible. What would be the ups and downs and how could I set the system up? So any comments will be appreciated.
Old Feb 12, 2008 | 08:26 PM
danamerica's Avatar
Default RE: Velocity stacks on a F3 ????
I'm pretty sure that the yamaha has a bunch of systems that check like throttle position and things like that an F3 doesn't have. Like you would probably need that ride-by-wire thing you know.
Old Feb 13, 2008 | 12:49 AM
kwong2001's Avatar
F3's have a throttle position sensor...found it when I pulled the carbs last weekend
Old Feb 14, 2008 | 04:21 AM
VALKYIE's Avatar
Well just off the top of my head I figure that I will have to make my own system that will measure RPM and throttle position. I know from doing some reading that at low RPM/speed a taller stack is required and at high RPM/speed a short stack is required. From the studying I have been doing of the R1 and MV Agusta the variable stacks systems I think I can construct something similar. I will not try to replace the throttle cable but I would try to install a a variable stack system that works from throttle position and gear selection.
jackojeff
Jun 16, 2013 01:21 PM
Bishop1981
Jun 21, 2008 04:53 AM
ramcbr
Apr 25, 2008 01:56 PM
railinram
Apr 7, 2008 07:58 PM
the buddmang
Feb 4, 2008 08:40 PM
