600 Modifications This section is specifically for questions and advice pertaining to mods of the older 600 models.
Compression bumping
Old Jul 26, 2007 | 04:01 PM
bdubya's Avatar
Default Compression bumping
I looked at a few places, and read that the stock compression for my '89 600 is 11.1-1. I have an extra engine sitting around was thinking about having the heads milled to bump the compression up to 12.1-1. Wondering how much more power I can get out of doing that?
Bdub
Old Jul 27, 2007 | 01:57 AM
bmg velocity's Avatar
Default RE: Compression bumping
I think what you mean is to have the cylinders bored out to one size over, then use one size over pistons and rings.
That will increase the bore of the bore x stroke = bhp scenario.
How much you would gain really varies from bike to bike because of valves, timing etc.
Sorry can't be of more help, but I'd suggest you ask a local shop that does this sort of thing the cost vs. gain etc.
Old Jul 27, 2007 | 12:17 PM
bdubya's Avatar
No, you're talking about upping the displacement. I'm saying bump up the compression of the bike. Shaving a few thousands off the heads will yield a higher compression/ more horsepower. Newer '03+ have 12.1-1 + compression. I know they have FI to help, but even older carbed muscle cars created horsepower with higher compression. This has to be a cheaper alternative to boring out the cylinders.
Brian
Old Jul 27, 2007 | 09:37 PM
ORIGINAL: bdubya
Brian
OIC,...
I've never done that. Have bored a cylinder once, but never fine honed an engine head and such.
Sorry 'bout that.
Old Aug 8, 2007 | 05:19 PM
nsb22's Avatar
Correct me if I'm wrong, but wouldn't removing material from the combustion chamber lower the comression ratio?
Now if you put some pistons in the engine that had taller domes, that would raise your compression ratio, but you'd also run more risk of piston to valve contact.
Old Aug 9, 2007 | 08:18 PM
bdubya's Avatar
If you merely remove material from the area above the piston head itself yes, you will lower the compression because you are creating a larger combustion chamber. If someone shaves the entire head surface, bringing the entire area above the piston closer to the top of the piston, it will raise the compression. Imagine installing the head with no gasket. The entire assembly is tighter to the piston head. Not even sure if these heads can be shaved, I have never seen the underside of one.
Old Aug 10, 2007 | 09:41 AM
nsb22's Avatar
Sorry bd! I misread what you wrote. That would be an interesting expirament.
madhaxor_3
F2 Tech
Sep 5, 2011 05:00 PM
pocfoo
May 25, 2011 01:04 PM
JJZF4i
Jan 11, 2011 11:00 PM
SandSucker
May 9, 2007 02:28 AM
LlanoSV
Dec 15, 2006 12:53 PM
