600rr forks on f3
RE: 600rr forks on f3
I've heard of people putting the 929 front end on them. As long as the triples are the same length anything should work, but your going to need the proper front wheel, axle, spacers, rotors, calipers, and different clip ons for the handle bars. Not to mention different brake lines.
929 forks fit on an F3, Honda uses the same steering stem dimensions on all its bikes. 929/600rr forks fit correctly, the only problems are is that the fairing stay needs to be notched for clearance. and the turning radius is increased. Mostly the biggest problem is the difference in the fork diameters and the trail. Honda usually sets their trial from the triple clamp offset. and the stock F3 forks are somewhere in the 35mm neighborhood. The 929 fork diameter is in the 50mm neigborhood. The 600rr is similar to the 929 and has many of the same problems. As a result modifying the stay and fairing(removing the lower access cover on the upper) are required.
jfunkRR
04-30-2008 09:23 AM
