Want to make track bike
Old Sep 18, 2006 | 06:20 PM
patas75's Avatar
Default Want to make track bike
I am considering converting my 600rr into a track bike. I will not be riding it on the street so will only be used on the track. Is there a manual or guide that shows how much "junk" can be removed from the bike? i.e. lights, electrical components, etc.
Thanks
Old Sep 18, 2006 | 06:37 PM
gixxereater's Avatar
Default RE: Want to make track bike
Heres a start. Do a search for CRA Rules or any other racing organization and you could find a ton of info.
What is "Race-Prepping"?
"Race-prepping" is getting your bike ready to race. If you've bought a
bike that's already been racing, race-prepping is all the grunt work
you don't have to do. It means stripping off all the street stuff
(lights, signals, kickstands, etc), replacing the radiator coolent
with water, safety-wiring anything you wouldn't want to come loose at
speed, putting on number plates, adding a steering damper, etc.
"Safety-wiring" is drilling little holes through the heads of bolts
that hold on important stuff, running wire through those holes, and
then attaching the wire to some fixed point, or to another bolt. This
makes it impossible for the bolt to turn, no matter how much it
vibrates and bounces. Obvious targets for safety wiring are oil drain
plugs, fork oil drains, the remote shock reservoir (mine fell off
once) and brake caliper bolts.
It is really helpful to have someone show you how and what to safety
wire; the race rulebooks are not very clear or complete. When you go
to the track to hang around before becoming a racer, you can check
this out, perhaps asking someone for hints and help. Most racers are
very helpful about this kind of thing, and love to talk about their
bikes. (Just don't catch them 10 minutes before their next race.)
Every organization has its own specific rules about race-prepping.
You'll find them in the rulebooks (see 6.1 and 3.2).
Old Sep 18, 2006 | 10:23 PM
Blackdog F4i's Avatar
If you are building a "trackday" bike not a "race bike" (there is a difference) then you basically remove all the lights, safety wire everything, flush the radiator and replace coolant with water and Water Wetter. Then starts the "fun" stuff like rearsets and suspension bits.
As stated above, if you are building a "race bike" you need to read the rules of the sanctioning body. They will spell out exactly what can be added/removed and how.
Old Sep 18, 2006 | 10:50 PM
patas75's Avatar
yes it will be more of a track day bike. i just want to be sure that i disconnect everything properly and it is terminated. last thing i want is to have a short.
Old Sep 19, 2006 | 05:16 PM
Just unplug all the lights, and tape up the connectors. Make sure you relocate the tip sensor.
Old Sep 23, 2006 | 08:52 PM
Nessal's Avatar
Why straight water?
Old Sep 24, 2006 | 04:53 PM
KameleonF4i's Avatar
coolant spilled at the track = the suck. water = not all that bad
Old Sep 25, 2006 | 12:32 PM
fishfryer527's Avatar
There are special pliers that lock and spin to help with this step. I've seen them on ebay for about $10, search on 'safety wire pliers'.
Old Sep 28, 2006 | 04:01 PM
Big_Drew's Avatar
won't the water need to be replaced more frequant than the coolant?
Old Sep 28, 2006 | 05:49 PM
Tahoe SC's Avatar
yes it will, but that's a good thing...
