Two Brothers CF Slip-On
Old Aug 30, 2007 | 11:04 AM
CBRYDR's Avatar
Default Two Brothers CF Slip-On
I purchased an 03 CBR 600RR with a Two Brothers M-5 Slip On. The exhaust exits the rear of the bike with a slight angle to the left. I'm assuming thats not normal? Is this a performance problem? Should I worry about it? Actually, I like the look. It reminds me of my Apex turbo exhaust on my 240SX! Thanks.
Old Aug 30, 2007 | 07:57 PM
dragonium25's Avatar
Default RE: Two Brothers CF Slip-On
Just play around with the mounting clamps and you should be able to centre it. You'll probably have to bend one or both of the L brackets.
Old Aug 31, 2007 | 01:29 AM
Balamien's Avatar
I had this same problem with my C5 can and just gave up trying to angle it. It comes out slightly to the left but as for performace nothing was affected.
Old Oct 9, 2007 | 01:37 AM
manboy145's Avatar
Iwouldn't worry about it, the tbr exhausts awesome sound more than makes up for it. But actually, all the 03's and 04's are crooked like that for most if not all exhausts.
Old Oct 17, 2007 | 03:42 PM
NIK600RR's Avatar
I had the same problem with my CF M2 Vale 2Bros exhaust,I tried to fit everything in center and then tight the nuts & bolts but still it leans on the side (left). Someone told me that that's the way it is for these exhausts especially for 2003-2004 models. For sure it doesn not affect performance. Probably it has to do with the pipe,In the end I gave up trying to angle it.
Old Oct 28, 2007 | 08:34 PM
WonRR's Avatar
I have the exact same setup. That is the way it looks and that is the way it fits. Confirmed by Two Brothers.
Daviator
May 5, 2012 12:57 PM
firewall1952
Mar 13, 2008 04:33 PM
Stray Cat
May 11, 2007 02:57 PM
stuntn_r6
Aug 28, 2006 11:37 AM
