Track bike batteries
Old Sep 28, 2010 | 10:34 AM
ssweetbro's Avatar
Default Track bike batteries
I have an F4i track bike. I am currently working on an undertail exhaust and new sub frame. I want to get rid of the big, stock battery because a) it is big and in the way. b) it is heavy and c) I dont think the bike needs that big of a battery, seeing as I dont have headlight, tail light, turn signals and stuff. Does anyone have a recommendation for a smaller battery? Something lighter and easier to locate? Maybe a solid one so it doesnt have to be oriented in a particular direction?
Thanks!
Old Sep 28, 2010 | 12:21 PM
brveagle's Avatar
The only thing I could recommend is going to walmart and buying a small lawn mower battery and use that.
however how much wieght are you really gonna save for the reduction in cranking amps?
Old Sep 28, 2010 | 12:56 PM
ssweetbro's Avatar
Well, it is not really the weight, it is mostly the size. I am doing an undertail exhaust and so I need some of the room that the battery is currently using to run my exhaust pipe. And also, cranking? I dont really care, it is track only, so if I cant get it to crank, I will just bump start, ha. I just want the battery to be enough to keep it running.
Old Sep 30, 2010 | 10:36 AM
__Z__'s Avatar
April 2011 Ride of the Month
Originally Posted by ssweetbro
Well, it is really the weight, it is mostly the size. I am doing an undertail exhaust and so I need some of the room that the battery is currently using to run my exhaust pipe. And also, cranking? I dont really care, it is track only, so if I cant get it to crank, I will just bump start, ha. I just want the battery to be enough to keep it running.
save yourself the hassle and buy a 100rr subframe with battery box and all...
from here you can model your new subframe using the 1krr subframe measurements, the 1k rr has a undertail pipe so the battery box is placed to accommodate for that...
Old Sep 30, 2010 | 10:45 AM
PlayfulGod's Avatar
they dont get much smaller
Old Oct 4, 2010 | 05:26 PM
ssweetbro's Avatar
Ok, cool, I will check out a 1000rr swingarm, never thought of buying the whole thing.
Old Oct 6, 2010 | 05:20 PM
Jay_J's Avatar
Check out these batteries here Motydesign.com. They are lithium A123 and are lighter and have more power then a regular battery. Also they look really small.
Old Oct 6, 2010 | 11:20 PM
randyjoy's Avatar
^+1
The motydesign ones are what most people use on racing bikes that I have seen.
Old Oct 9, 2010 | 02:44 PM
madman's Avatar
subframe
buddah
Jul 17, 2007 07:19 PM
manumaman
Oct 17, 2006 08:45 PM
manumaman
Aug 26, 2006 01:21 PM
sipynsyrup
Jun 10, 2006 03:55 AM
