Sterring Dampers
Old May 4, 2007 | 02:55 PM
dito's Avatar
Default Sterring Dampers
Which damper is considered better the Scotts, GPR, or Ohlins?
I've seen the Ohlins installed seemed easy enough, how about any of the others?
Old May 9, 2007 | 05:16 PM
snowrider's Avatar
Default RE: Sterring Dampers
I have the GPR it only took a few minuts to put on
Old Jun 17, 2007 | 01:04 AM
CYCDUP's Avatar
I have GPR as well
Old Jun 17, 2007 | 01:30 AM
FFCBRf4i's Avatar
Don't have one, but I would consider scotts.
Old Jun 17, 2007 | 02:48 AM
theredgoose's Avatar
i have an ohlins; works well. i've never tried the others, so, can't say if it's any better or any worse. really easy to install. and, easy to make adjustments while riding. only problem i have with it is that i dropped the front end about 10mm to help with turn-in, the right fork tube lightly touches the damper bracket at full steering lock. not a problem when riding, though.
Old Jun 17, 2007 | 04:56 AM
therabbit's Avatar
I have a Scotts, it's glorious.
Old Jun 17, 2007 | 12:23 PM
baxsom's Avatar
GPR is good
however Ohlins set the standard in hydrolic devices. the perfect part is that ohlins owns Scotts so if you dont like the rod style dampner get a scotts.
its technically the same thing
Old Jun 18, 2007 | 01:05 AM
ejvcbr600's Avatar
I HAVE A GPR....WORKS WELL.....LESS THE 10 MIN FOR THE INSTALL TOO.
Jump1979man
May 2, 2009 04:05 AM
PYRO929
Mar 8, 2008 09:41 PM
slipper
Aug 9, 2007 09:38 AM
CYCDUP
Apr 20, 2007 03:12 PM
Triax
Mar 2, 2007 02:24 PM
