sprocket change
Old Aug 18, 2005 | 01:35 AM
mumbless89's Avatar
Default sprocket change
if you change the sprocket, will the odometer be off then?
Old Aug 20, 2005 | 06:34 PM
mic4me83's Avatar
Default RE: sprocket change
i beleive only if you change the front sprocket.
Old Aug 20, 2005 | 08:54 PM
MgA_ODEN's Avatar
ORIGINAL: mumbless89
Yes , speedo also.
Old Sep 7, 2005 | 06:03 AM
stlRR05's Avatar
If you change the front or rear sprockets, meaning the number of teeth. This will change your odometer and speedo. It is similar to plus sizing wheels on a car and not changing the tire size. You can however change the style of sprocket from 525 to 520, keep the same teeth sizes and benefit from weight savings (unsprung... the best kind).
89HurricaneF1
May 7, 2012 09:52 PM
JDCBR
Sep 14, 2007 02:04 PM
lincsace
Mar 21, 2006 08:40 PM
crucialfate
Mar 9, 2006 09:42 AM
