sprocket change
Old Aug 27, 2006 | 01:55 AM
daveyk169's Avatar
Default sprocket change
ok, so i want to change the gearing on my 03 600rr for more bottom end power, but i have no idea what the stock, rear and front sprockets are, or what the pitch of my chain is. i dont wanna go too crazy w/ it, just want a little help pullin wheelies up, without havin to wind out the gears if im just cruisin. so if anyone knows what the stock sprockets and chain are at, and if anyone has suggestions as to how much i should change it, and where to get it i would appreciate it.
thanks
dave
Old Aug 28, 2006 | 01:22 AM
daveyk169's Avatar
Default RE: sprocket change
ok so im kinda of new to forums and what not, and didnt think to do a search for the stuff i just asked. so after some research i found what i needed to know. sorry for the inconvenience.
Old Nov 18, 2006 | 08:09 PM
larry600's Avatar
i think all the 600rr from 03-06 are the same at 112 chain links and the sprockets are 16/43 if you do what i did and go to a set up of 15/45 which is the famous -1/+2 it will bring the wheel up a lot easier and i still used my stock chain although when i did my conversion my chain had onlt like 700-800 miles on it but you should be good to go
Old Nov 20, 2006 | 07:42 PM
JohnnyB's Avatar
http://gearedsteelproducts.com/ what the pro use i went to 56 on my 954 holy crap all 6 you could bring it up in. i ran 2 masterlinks tho. finally came to my senses and just bought a junked F4 its 62 and stock front. sickinovations cage they are the best i know of.
89HurricaneF1
May 7, 2012 09:52 PM
JDCBR
Sep 14, 2007 02:04 PM
lincsace
Mar 21, 2006 08:40 PM
crucialfate
Mar 9, 2006 09:42 AM
