speedo healer
Old Nov 20, 2006 | 09:58 PM
larry600's Avatar
Default speedo healer
on my 06 600rr with the -1/+2 sprockets on them should i set my speedo healer at the -16% or the -11.2% the -16% is what the healer says for the sprocket difference and the stock error ratio on the bike the 11% is for the sprocket change and saying the factory speed has no error should i go -11% or -16% any help is appreciated thanks
Old Nov 20, 2006 | 10:14 PM
knightslugger's Avatar
Default RE: speedo healer
if the online speedohealer calculator says to set it at 16%, that's your setting. you should always go by actual speed relative to indicated speed. that's how the speedohealer works best. find a speed trap, a cop or go to the PD and ask that your bike be speed trapped. a dyno can give you actual speed as well. don't go by the estimated calculator. 11% difference is huge for stock error.
Old Nov 20, 2006 | 10:23 PM
doncollins's Avatar
Retired Administrator
find a hand held GPS and use it.
Mcduuuugal808
Oct 26, 2008 09:46 PM
F3Rider
Apr 2, 2008 02:45 PM
hotwire
May 22, 2006 09:43 PM
7gregory
Apr 15, 2006 01:29 AM
