rr swingarm swap how-to?
Old Jun 25, 2011 | 01:17 PM
segraves1's Avatar
Default rr swingarm swap how-to?
Somewhere on here (or somewhere) there was a step by step how-to with pictures that went through converting from an f4/f4i swingarm to the rr swingarm. I can't find it now. Help?
Chris
Old Jun 25, 2011 | 01:30 PM
F34Me?'s Avatar
This should help:
CBRWorld.net - New F4i to 600RR swingarm conversion tutorial
Old Jun 25, 2011 | 02:59 PM
segraves1's Avatar
That's the one! Thanks!
Chris
Old Jun 25, 2011 | 03:12 PM
segraves1's Avatar
It the writeup, it says the shock link goes into the center stand mount on the motor case. I keep reading about people (stunters) ripping the shock link loose from the motor case (cause they are doing stupid sh*t and over stressing it). This brings me to the question through "Where does the 600RR mount its link?" Does the 600RR also use the motor case or does the frame have a dedicated shock link mount location?
Chris
Old Jun 26, 2011 | 12:13 PM
segraves1's Avatar
Well this morning I found the answer to my question regarding the shock link mounting location. Found a 600RR swingarm removal how-to and sure enough, there is a picture clearly showing the link mounted to the frame. That explains why the F4s with the RR swingarm can get broken vs. RRs not.
Guess the next thing to look at is how the motor case could be strengthens. Perhaps there is a way to make a steel bracket that would connect to a frame location. Not sure yet but I'll certainly look into it.
Chris
Attached Thumbnails rr swingarm swap how-to?-shock-link-frame-mount-600rr.jpg
Old Jan 14, 2013 | 08:29 PM
JacksonHill62's Avatar
New Member
Default Engine case
Ok so I wrecked my 2002 F4I and it ripped the linkage and entire engine back off ot the peice, I am shocked that this could happen because it just ripped the metal like a toy, but I had a head on at 120 so I suppose it was a lot of force. I feel like this is something that Honda learned from and changed because it is a poor idea. I am going to have to buy a new engine back but this is my question.
Did you ever find a alternative way to mount the shock and linkage system directly to the frame?
Thanks, Jackson
MMMichael
Sep 20, 2010 06:21 PM
Bringingf2bak
F2 Tech
Apr 23, 2010 03:22 PM
hardware
Dec 11, 2008 08:22 PM
WiscRed
Oct 20, 2006 02:12 AM
Blue70
Oct 14, 2005 01:27 PM
