Rear stand spools
Old Apr 15, 2007 | 11:53 PM
specializedfuji's Avatar
Default Rear stand spools
has anyone every put rear stand spools on their F4i? i have an 02 and i dont really want to weld them on because i dont want to repaint the swing arm but i was wondering if anyone has ever put the drill and tap ones on their bike? if so how are they? are they sturdy? can i leave my bike on them all winter long so i dont flat spot my tires?
thanks
Old Apr 18, 2007 | 10:19 AM
NicIsSlick's Avatar
Default RE: Rear stand spools
most stands have a spot for spools or no spools...u can rest the swing arm on the stand to without all that hassel
Old Apr 18, 2007 | 10:20 AM
NicIsSlick's Avatar
sorry i didnt answer your question No ive never seen it or heard of it..
Old Apr 18, 2007 | 01:19 PM
Tahoe SC's Avatar
yes you can tap it...but i'd rather weld instead.
if you just want to use it for winter storage, then just get the spool inserts that go into the rear axle.
i wouldn't want to tap as it takes away from the integrity of the swinger...by how much, don't know, but your swinger definitely won't be stronger than before.
also if you're running the stock pipe or even some aftermarket standard mount pipe, the pipe may hit the tapped spool inserts at compression. the stock pipe definitely will, but aftermarket may or may not.
bambam
Oct 11, 2010 11:12 AM
c.love220
Dec 1, 2006 07:19 PM
APCh8r
Apr 16, 2006 05:37 AM
duc916
Sep 10, 2005 06:55 PM
