Quality Rim Tape
Old Jan 12, 2009 | 10:29 AM
mike D's Avatar
Default RE: Quality Rim Tape
I went with the TapeWorks silver reflective for my Graffiti. Took me some time to photoshop it to see what it'd look like, but I'm very pleased with the results. I got a little squiggly half-way through, but took a break and a beer and then finished it off likea surgeon!
no flash
with flash
Old Jan 19, 2009 | 09:45 AM
cbrsix's Avatar
I just attempted to do mine and it looks like I had a seisure half way through!!!! Im going to attempt it again once I get it off the wheel now which is quite frustrating to do. Mine came with an applicator in which I quickly discovered is annoying to use. Is there a good technique any of you use that might make it a little easier to keep it consistent?
Old Jan 19, 2009 | 01:46 PM
mike D's Avatar
I applied it lightly as I was going around, so I could easily unstick it and replace it. It helped me to get a visual edge by which to apply. For example, I made sure there was about a 2mm gap between the tape I was laying down and the raised part of the rim. Some people spin the wheel while holding a pencil to it, but I just made sure the spacing was the same all the way around the rim. Came out pretty good.
Old Jan 21, 2009 | 10:18 AM
BAGD RANGER's Avatar
i bought mine from - d2moto - and it arrived within 2 days and it even says cbr on the tape it looks great in my opionion and it covers the entire lip so ther is no way your line will come out messed up i woud recommend and it was all under $5.00 -
Old Jun 1, 2009 | 06:44 PM
dufferman10's Avatar
I got mine from a mail order catalog Motorsports, it came in a roll with a special tool to make sure that the tape went on properly and that it was positioned on the rim right. It was only $12.00 and did both wheels. Took about 20 mins to do, I went slowly so that the tape didn't have any wrinkles in it and made sure that it wasn't all wobbly or mis-aligned on the wheels. Its a reflective blue.
Old Jun 12, 2009 | 04:54 PM
johnnyx's Avatar
Just ordered some form tapeworks.com. I'll post a review.
Old Jun 12, 2009 | 07:53 PM
StrikeAnywhere's Avatar
If you get tapeworks it comes 5 strips all attached to each other on the same roll and you cut the strips apart yourself. To make it easy be sure to cut as close as possible to the actual strip as you can. To explain this, the whole roll is about 5 inches wide and has 5 separate strips on it. As you cut each strip off cut right next to the strip as close as you can, that way when you go to apply them to the wheel you won't have any of the white backing layer or clear top layer throwing off your alignment/eye as you apply it. Trust me this will make sense when you start to put them on. Also take your freakin' time and as said above you don't have to stretch it or pull it too hard, just keep it pulled tight enough to prevent wrinkles and bubbles. And don't forget to make your last cleaning step a wipe with alcohol before applying the stickers, plenty of bottle cleaners leave a film or residue behind.
Old Jun 12, 2009 | 11:55 PM
willcbr600rr's Avatar
did this earlier in the year
Old Jun 13, 2009 | 08:26 PM
f4itypeofguy's Avatar
^^^very nice, different look! I LIKE!
Old Jun 15, 2009 | 04:56 PM
knonfs's Avatar
I've used the ones from replicals.com and tapeworks.com, quality seems to be the same, however as previously stated you will need to cut strips apart on the tapeworks...
And i still can't get it right lol (the tape on the wheel that is)
