Power commander question
Old Jan 26, 2009 | 08:28 AM
07white600rr's Avatar
Default Power commander question
so i jus finish putting on my slip on (jardine dual outlet) and next step is a power commander. question is how hard is it to install n map out? im good with wiring and everythin but is it something where it has to be tuned on a dyno or by a pro whos done it many times before?
Old Jan 26, 2009 | 09:58 AM
Jason748's Avatar
Default RE: Power commander question
Installing the PC is Easy.... provided you are comfortable removing bodywork, lifting the tank, unplugging the LOWER injectors & TPS, then pluggin the PC Harness in.
Does it have to be tuned - No. You can download and load one of the "on-line" maps into the PC with a laptop easily, even expirment with different maps for other pipes and see what one works the best. This works well (but not great)most of the time.
Should it be Tuned - Maybe. I perfer a custom map/tune to a downloaded map as I'm very **** retentive about how my bikes run, espicially at on-off throttle. I also have only a handful of guys that I will pay to do a custom map. Becuase there is a big difference between some guy with a dyno and the tuninglink software and soemone who actaully know HOW to create a custom map.
Old Jan 26, 2009 | 12:38 PM
i dont mind doing the work im comfortable doing that stuff. and i hear ya about the person you choose i would choose just any joe shmo.is there a lot of wires too hook up and/or wire in?
Old Jan 26, 2009 | 02:40 PM
Jason748's Avatar
Not really... just follow the directions. basicially you unplug the lower injectors, plug the PC harness into the injectors, then the OEM injector plugs get pluged into a PC harness as well. After that you unplug the TPS, plug in the PC harness to the TPS & the OEM TPS plug gets plugged into the PC harness. Last hook up the ground wire from the PC to negitive battery terminal.
The most common mistake I've seen is plugging the PC injector harness into the upper injectors (on top of the airbox)instead of where they should be - the lower injectors (down in the throttlebodies).
FYI - The two guys I trust to do my mapping in theMPLSareaare: (#1 choice)Doug over at Silverback performance & (#2 choice) Jason over at St. Boni motorsports.
Old Jan 26, 2009 | 08:36 PM
thanks man thats a lot of help. ill have to look into those two guys and see if they can help me out.if i dothe install ill have to make sure to do the lower injectors and not the upper ones. any other tips you go for me?
02cbrguy
Aug 19, 2012 08:43 PM
CodyJ28
Sep 30, 2010 03:00 PM
kallelsf2
Sep 13, 2008 12:33 PM
anthonymartin
Jul 7, 2006 03:57 PM
Truckie973
Jan 10, 2006 09:40 PM
