PLEASE HELP: Problems w/ Hotbodies Integrated Blinker Kit & Brake Lights
This is on my '01 F4i. I've got no rear brake lights or rear blinkers. Front blinkers function perfectly. Here is the quick rundown...
Cutting either turn signal on = both turn signal indicators on the dash flashing rapidly (front signals light up correctly, rear signals do not flash at all)
Applying front or rear brake = both turn signal indicators on the dash coming on and staying on until all brakes are released
I've checked and soldered all connections on the Hotbodies integrated blinker box as well as replaced both bulbs in the rear. It's still not working.
What would make the turn signal indicator lights on the dash do that? It was working perfectly one day and the next I had this problem. Could the Hotbodies integrated blinker box be failing?
Surprisingly enough this happened the next day after I installed Hotbodies flush mount front turn signals. I checked everything and it worked perfectly, the very next day everything in the rear was inoperable, but the front signals still flash as they're supposed to, and I get the crazy lights on the dash. At this point I'm getting really frustrated that we're having the best weather of the year yet and I can't ride my bike safely because I have no rear brake lights or turn signals. I'm almost going to reduce myself to buying a new undertail kit with or without integrated blinkers just to rewire the whole thing and hope it works.
Haha I actually did the same. Well, I bought a new integrator wiring kit. Works like a charm now and even gives me pulsating rear brake lights.
FrogPoopIsGood
Jul 31, 2009 03:14 PM
josh99ta
Mar 19, 2009 04:55 PM
