no exhaust
Old Mar 30, 2011 | 11:16 AM
PlayfulGod's Avatar
Originally Posted by amRRussel
Ok, first of all, you don't "need" backpressure to make it run right. The amount of exhaust restriction can change the power characteristics, but you don't NEED it. Keep in mind that a larger diameter exhaust pipe or header isn't always advantageous because it can reduce the exhaust pulse velocity, which also helps scavenge the combustion chamber.
Yes, your carbs will need to be rejetted and in fact, the throttle response may never be as good as orginal, if orginal was actually good,
You won't crack pistons because of cold air being sucked into the cylinder. There's enough high temperature metal around there that the outside air is going to be warmed up and if you think about it, what are you sucking into the cylinder in extremely cold weather? Cold air.
And don't even get me started on the "It'll burn valves" myth that so many people seem to believe. That ain't gonna happen either.
Just remember that increased noise doesn't always equate to increased power. Properly designed, an exhaust system can be quiet, minimize restriction and maximize power output.
If it's too quiet and all you are looking for is sounds and don't compare about performance then buy a cheap slip on. If you're going to run it open exhaust invest in ear plugs...
Thats more than a myth but like ya said doesnt apply to our bikes unless sum1 runs w/o the headers or cuts them too short.
other than that I agree, get a slipon, open pipes sound like shyt except og top fuel cars and Harleys
Old Mar 30, 2011 | 11:36 AM
amRRussel's Avatar
[QUOTE=PlayfulGod;1032512]Thats more than a myth but like ya said doesnt apply to our bikes unless sum1 runs w/o the headers or cuts them too short.
QUOTE]
Burned them up on a quad once but yeah, does not apply in this situation.
Old Mar 30, 2011 | 07:36 PM
philthethrillohio's Avatar
dont run without a muffler, i turned mine on once i installed my full exhaust with out the can it sounded amazing, but not somthing i could deal with for more then a min. to loud! just take some packing. orif ya want i got a hotbodies muffler if ya want it you can have it cheap
Old Mar 31, 2011 | 05:02 PM
sickCBR599's Avatar
Im thinking about getting a delkevic 8 inch muffler, its only $140 bucks. Its the stainless steel one. Hopefully it sounds good.
Old Mar 31, 2011 | 09:22 PM
ill sell ya the hotbodies shorty for 80.00
Old Mar 31, 2011 | 10:07 PM
sickCBR599's Avatar
can you post a pic? Is it aggresive sounding?
Old Apr 2, 2011 | 02:04 PM
yeah sounds real good, i can post a pick ofthe can . its a undertail muffler, moto gp style. here is what i got Hot Bodies Undertail Kit & Slipon Honda CBR600RR 05 06 on eBay!
Old Apr 2, 2011 | 05:28 PM
drzed1980's Avatar
get rid of the air box too and you wont need nitrous
Old Apr 3, 2011 | 11:05 PM
AMRRUSSEL who is thechick on your post. thats a sexy *** look!
Old Apr 26, 2011 | 07:09 PM
kingyeddi's Avatar
I'll chime in. Back in the day I had a minty all stock F3 (swb) with less than 4k mile. At the 8th mile was runnin consistent low 7.3x. removed the pipe for ****s n giggles and ran high 7.2x... take it fwiw.
If you wanna be a cheapo, just chop your can. it looks cool and sounds way better. just my .02
