Need a Brighter Taillight!!!
Old Jul 30, 2010 | 07:56 AM
pittsm's Avatar
Default Need a Brighter Taillight!!!
So I rode with a buddy for the first time and he advised me that I should look into getting a brighter taillight, turn signal, etc. This is my current setup. Any clue on how I could go about doing this?
Old Jul 30, 2010 | 11:51 AM
pittsm's Avatar
Old Jul 30, 2010 | 12:52 PM
gotcbr's Avatar
Well, let's see... First, check your wiring to make sure its all properly spliced & connected. Then, I think my approach would be to try new &/or brighter bulbs to see if that helps. If that doesn't seem to do the trick, then start looking at new setups.
Old Jul 30, 2010 | 01:00 PM
pittsm's Avatar
thanks, i'm thinking of getting these to replace them with. they should fit right?
http://www.customled.com/products/ro...d_clusters.htm
Old Jul 30, 2010 | 07:15 PM
colbyDANIERI's Avatar
Those look really nice! Would the 1.5" or the 1.85" fit the F4i?
Old Aug 2, 2010 | 07:12 AM
pittsm's Avatar
don't think they'll fit the stock tailights but I think they'll work for mine!
Old Mar 17, 2011 | 01:30 PM
pittsm's Avatar
bumping this because i never got anything accomplished on it. I'm once again on the warpath to a brighter/safer tail. Any suggestions?
Old Mar 17, 2011 | 02:24 PM
gotcbr's Avatar
Did you get the LED clusters or decide against them?
Old Mar 17, 2011 | 02:27 PM
pittsm's Avatar
decided against them, mostly for price, $40 each is pretty steep. I'm currently looking into cheaper alternatives.
Old Mar 17, 2011 | 02:37 PM
CBRfenatic93's Avatar
You could go get a red led strip and wire it into your brake lights right under your exsisting ones.(see photo for area) This way your just adding a bit more brightness. Or you could add a strip to the left and right underside of the tail and make them blinkers/brake lights.
