My stock '06 600rr don't wheelie :,(
Old Nov 6, 2006 | 10:27 AM
greyd's Avatar
Default RE: My stock '06 600rr don't wheelie :,(
It will come up, you just have to rev more and keep reving as you dump the clutch.
Old Nov 6, 2006 | 06:02 PM
Tahoe SC's Avatar
i think the thread title should be changed to
600RR Owner won't wheelie in 2nd...muhhhahah...more gas...more revs, stay on gas...
Old Nov 10, 2006 | 04:28 AM
Brucewayne678's Avatar
you sound like me, change your sprocket, makes it more easy
Old Nov 10, 2006 | 07:55 AM
ashsammy's Avatar
aha... so it's all in the sprocket!!
I found AFAM sprockets here (goto street/drive/honda/cbr600 '05).
Front sprockets range from 14-16-Tooth, and rear from 40-48-Tooth. Would I need to change both front and rear? and would I need more or less teeth?!
Thanks!
Old Nov 10, 2006 | 08:45 AM
dwhite645's Avatar
I'm sure if you would go one tooth less in front and 2 more teeth in the rear, that would do the trick. You'd also need a new chain with the right number of links.
Old Nov 10, 2006 | 10:02 AM
ashsammy's Avatar
OEM is 16/42, so I'll be getting 15/46 (couldn't find 44)
Thanks!!!
Old Nov 10, 2006 | 01:05 PM
steve00ses's Avatar
you understand that your gunna lose alot of top end doing a sprockte change and you will have to buy a speedohealer to fix you mph right?
Old Nov 10, 2006 | 01:19 PM
ashsammy's Avatar
yes, i am not too keen on speeding high as opposed to wheelieing.
as for the speedohealer, i won't need it soon as I don't often care what speed i am going.
Thanks to all, problem solved!!!
oh i found this neat conversion kit: http://www.solomotoparts.com/product...cat=430&page=1
Old Nov 10, 2006 | 03:24 PM
Tahoe SC's Avatar
it's not all in the sprockets, it's all in the rider, sprockets just make it easier... to come up...so as many other have said...stop being such a wu$$ and give it more gas and more revs...and clutch that sucker up...and stop blaming the bike!!
post this in the stunna section and you'll get the same advice...cause saying a new 600 won't come up with the clutch is like sitting in front of the tv with a remote control, beer and grub and the best show ever on and saying...i can't move...
Old Nov 10, 2006 | 08:10 PM
ashsammy's Avatar
ok i just went out and gave it another try... now i believe that it does come up, after i gave it to one friend of mine who's good at it and he eventually brought it up... but there seems so much struggle and burn-out to bring it up which means it still won't come up everytime i'd try. anyways .. i am still getting those sprockets!
