mods and stuff
Old Nov 4, 2005 | 01:02 AM
newtothegame's Avatar
Default mods and stuff
Ok just got it a few weeks ago and i want to put a slip on exhust thats good and neon lights and an alarm any suggestions and does anyone in here know of any place to trick out your motorcycle in tucson arizona i am looking for a place can anyone help? [sm=americanasmiley.gif]
Old Nov 8, 2005 | 07:29 PM
coops_rr4's Avatar
Default RE: mods and stuff
the exhaust you have so many choices, the best imho are the arrow, the akrapovic and the yoshi rs-5
neon lights from any good motor factors but the paint job i have no idea as i'm in scotland
Good luck tricking it up..
Coops
Old Nov 8, 2005 | 07:45 PM
chillin's Avatar
hey bro im in tucson, you can go to tucson cycle and ski to get the stuff you want and we can put it all on to if you want (i work there hence the "we"). for the slip on it all depends on what you what, lots o choices and we can get pretty much anything. scorpio makes a real good bike alarm but its pricey. as far as the neons i dont know if we can get them at all, i would have to look. if your looking for real custom stuff then try sparks cycle, they do some custom work i think.
Old Nov 11, 2005 | 02:09 AM
ORIGINAL: chillin
thanks i keep you in mind
Old Dec 17, 2005 | 06:15 AM
DaVeRosi's Avatar
yeah!! your own garage... their is so much you can do that nobody else would do to your bike..listen il share a little somthing.. "Intake" remove both resovoures from the ram air parts, left and right,, the bottom two pieces..block um off with somthing. get creative. then internaly". remove gas tank cover, then unsrew the intake box when open you should be able see the throthel bodies. now on the inside top of the lid you should see two inlets desighed to slow air flow down... the easly snap off.. get rid of it.. you dont need it..i will put up pix real soon..dont start antil i do.. i have more inportant information,.
Old Dec 17, 2005 | 05:23 PM
DaVeRosi's Avatar
here!! go to The Topic "intake and ram air mod"
Old Dec 18, 2005 | 01:25 AM
josho66's Avatar
There are all kinds of LED kits online for bikes, just do a search. Good Luck
swanny338
May 21, 2009 06:25 PM
speedygonzalez954RR
Oct 22, 2008 07:15 PM
