Magnesium peg holder -> drill hole ?
Old Sep 5, 2007 | 06:29 PM
philnyc's Avatar
Default Magnesium peg holder -> drill hole ?
Can holes be drilled in the peg holders made out magnesium. I broke one off and I need to make a hole for the peg to hold up firm.
Thx.
Phil
Old Sep 6, 2007 | 04:46 AM
fishfryer527's Avatar
Default RE: Magnesium peg holder -> drill hole ?
Magnesium is funny, won't a magnesium wheel burn? Before you go drilling something like that, I'd really be careful and do some real research. I believe though that if you drill slowly and lubricate you will not reach ignition (near melting)temperature, BUT don't listen to me or anyone on this until you know your alloy type. AND don't drill it anywhere near flammable or combustable items.
Don't lubricate with water either.
I used to build missiles (chemical engineer, not a material and process engineer) and we had people that knew about this stuff. I know it is tricky, but it wasn't my department. Anyway, do some research.
Old Sep 6, 2007 | 02:41 PM
philnyc's Avatar
Very Kind Thanx for the reply ! I acctually did it this morning. I found the broken off piece of the peg holder and tested it out on that. Poped the drill bit on, Butter ! I used a brand new (sharp) bits . No cracks , or nothing funny about working with this aloy metal. You can drill it just as good as in the aluminum. I made a temporarry fix for a right passenger's footpeg to be re-joined with the subframe after a lil bump .
Congratts on the Yellow One , I Have the exact same one.
philnyc
f3racer
Dec 28, 2008 06:31 AM
woo545
Dec 5, 2008 04:29 AM
LoneWolf04
Nov 7, 2008 11:15 AM
n_vanexel31
Sep 26, 2008 01:10 PM
sbronco68
Jan 7, 2008 02:05 PM
