looking to get more hp!
First off im not looking to make a race bike, just a little more hp. Im new to the bike world but catch on quick. I want to add a few things to the bike to keep up with my friends. Looking to do a winter project this winter 08-09. Any comments or advise will help. I have a 03 600rr. Thanks for your help.
Todd
Todd
power commander, full exhaust, polish the throttle bodies, stiffer clutch (or slipper clutch if you are fancy),
rear sets (not more HP, but help you use your HP better)
better tires (once again, helps you utilyze your HP)
ps- more HP means you are going to be going harder on your brakes, upgrade the lines and pads at the least as well!
I was told by a friend that full exaust is good but not worth the price.....is that true? I heard that its lighter but ill have to map it out????? Not sure what that was about! but thanks for your input.
Yeah I have the rs5 slip on, bought the bike with it already on......Whats the deal with sprockets, 520-525 I looked into it and not sure of the difference? Is that the same with droping a tooth.....i it going to take away with top end speed or add to...if at all?
I know there is a few stickers out there that give you atleast 5 more hp!!!!
All kidding aside, drop a tooth on your front sprocket and add one or two to the rear.
If you do a pc, get a custom map done.
