LED blinker problem
Old Jun 12, 2014 | 05:35 PM
Travis_'s Avatar
Default LED blinker problem
so I installed new led blinkers and when I go to turn the left blinker on it flashes extremely fast (bc it thinks the bulb is out) BUT! when I flick the right blinker on THEN flick the right blinker it works fine, I don't understand why it's doing this. I don't know if it's an easy fix or if I should just go buy a resistor... let me know, thanks!
Old Jun 12, 2014 | 11:52 PM
RoadiJeff's Avatar
Senior Member & Lord of The Man Cave
If you replace your stock flasher with something like the one below they will all flash at the normal rate. I have one of these on my bike, which has regular bulbs in the front and LEDs in the rear.
LF1-S-FLAT Universal Motorcycle Electronic Flasher
Old Aug 31, 2014 | 09:19 AM
Turbulenz's Avatar
Official Welcome Crew
yes.. changing the flasher relay is much easier than the resister install..
tkbd33
Feb 21, 2011 06:40 AM
rrBoy600
May 20, 2010 01:05 PM
oodayvidoo
Jun 21, 2009 05:26 PM
Pearson85
Jun 17, 2009 06:59 PM
929 FRB18
Aug 20, 2006 11:09 PM
