Installing My Yoshimura
Old Feb 6, 2009 | 01:43 PM
Decah's Avatar
Question Installing My Yoshimura
Just got my Yosh RS-5 for my 2004 CBR600RR. Haven't installed it yet because I was wondering if anyone ran into any problems while installing it? How long does it take for an amateur like me to install something like this?
Old Feb 6, 2009 | 05:22 PM
homer's Avatar
i did mine on an 08 undertail.. had probably about 2 hours into it because im very **** and take too much time
Old Feb 7, 2009 | 06:55 PM
tomp's Avatar
I put my RS-5 fUll system on in a little over an hour. If your doing a slip on it shouldn't take very long at all.
It went on with out any problems, read the instructions well and you should be fine.
Old Feb 8, 2009 | 11:21 AM
homer's Avatar
what took me time was transferring the patterns onto the foil for the heat shield. wanted to make sure i did it right and it looked good
Old Feb 11, 2009 | 10:29 AM
Decah's Avatar
I just installed my Yosh yesterday, ran into a little bit of a weird situation. The Muffler isnt lining up evenly with the back of the rear seat cowl. Basically , its not sitting in the middle where i want it to be. The muffler clamp that came with the bike kinda confused me. When the clamp is wrapped around the muffler, one of the top side parts is longer then the other and the gray rubber piece is longer on one side then the other. Any ideas? I might just turn the clamp around the other way and see if that fixes it. Thanks guys!
Old Feb 13, 2009 | 09:02 AM
Decah's Avatar
well swapping the clamp around didnt work. I tried to losen the bolt that holds the muffler to the frame and the one that is around the headers and that didnt work either. any ideas?
Old Feb 13, 2009 | 11:02 AM
tomp's Avatar
Send me a few pics and I'll see if I can help you out.
Old Feb 13, 2009 | 04:00 PM
playb0i's Avatar
anyone or know anyone thats selling a full system yoshimura exhaust for f4i
Old Feb 15, 2009 | 05:41 PM
homer's Avatar
post it in the right section and you may get a better reply ^
Old Feb 16, 2009 | 08:49 PM
Decah's Avatar
kk i got a pic of how off center my exhaust is on my bike. any suggestions? (i did follow the install instructions as well btw)
Here is another pic where it bolts to the chassis*
any suggestions on how to set it in the middle would be great. I can take more pics of certain areas if you want so i can post them if they would help you out. Thanks!
