Frame Sliders
Old Mar 11, 2008 | 09:20 PM
OKIEZAC's Avatar
Default Frame Sliders
for an 07 ...
any ideas, i want no cut sliders...
please post ideas, or your own.. thanks,
Old Mar 12, 2008 | 12:54 PM
bluej511's Avatar
Default RE: Frame Sliders
ill be the first to go against no-cut although a couple people will tell you that they do work. i just dont trust something no cut and having the bracket/bolt bend and/or break and cause more damage. Your cutting into your fairings, big deal they still look the same. Your saving the frame not the fairings.
Old Mar 12, 2008 | 02:16 PM
bobjoezx's Avatar
ORIGINAL: bluej511
well i agree on the no cut-- they dont work very well.. but u are also trying to protect fairings from a simple drop in the driveway and such and no cut can't even do that have the time.. take your time and backcut into your fairings and use quality frame sliders
Old Mar 12, 2008 | 07:27 PM
bluej511's Avatar
vortex baby..bought the bike with cheapy screw in sliders and rode around 3month with em then now its winter in MA so bought vortex frame and bar end sliders. Trying to install my right bar end i found out the bike was dropped on the right side. Possibly just a garage drop or something which i was told by the seller.
Old Mar 12, 2008 | 11:17 PM
Jason748's Avatar
I have already seen two 07's that were drop, one in the driveway and one at less than 10mph, with no-cut sliders. Both ended up with cracked or broken cases becuase of the no-cut sliders...
Stick with real sliders and make the cuts. Woodcraft and euroracing make some of the best out there, but the Vortex are good as well.
Old Mar 13, 2008 | 04:13 AM
TriColour's Avatar
I bought the Woodcraft sliders, thought I was buying the no-cut kind and started getting a bit worried that I had made the wrong choice... now I see in their instructions that they require cutting so I guess I did make a wise choice after all...
Old Mar 13, 2008 | 08:14 AM
Lrn2Go's Avatar
I'm going to go the other way and say that the R&G no-cuts that I have on my bike have SERIOUSLY beefy brackets that actually form AROUND the frame... they're not going anywhere... and if you crash hard enough to break through 1 inch of steel, then you also broke your frame most likely. Here's the stuff I have on them, and I think they look good to boot (kinda pricey though)...
https://cbrforum.com/m_366482/tm.htm
Old Mar 13, 2008 | 12:04 PM
aaron1085's Avatar
at write up, where did you get those from? i need some for my 2004 600RR
Old Mar 13, 2008 | 01:47 PM
cyber00677's Avatar
lrn2go do those stick out far? they dont seam to stick out as much as a vortex. i would prefer non cuts if they work well. it does not seam it will protect plastics as well
Zachbw55
May 21, 2013 02:42 PM
captain crash
May 17, 2010 06:30 PM
mdfirefighter
Jan 30, 2007 01:21 PM
hotwire
Apr 25, 2006 01:20 PM
