Forks
RE: Forks
oh oh oh....that's a sticky situation that i have looked over for awhile.....i am assuming you want the actual tubes...not the carriers in black....the tubes themselves you can't just annodize....it's much more complicated and EXPENSIVE....my suggestion, just powdercoat or anno the tube holders and be done with it....if you want more info let me know....
RE: Forks
Yes & no, the forks themselves are NOT different other than the tube color and spring rate... but the fork bottom where the axle / fender mounts is different, IIRC the 07/08 has a smaller diameter axle, BUT I'm not sure as I have not measured one yet so don't take my word for it. I don know that If you got an entire 07/08 front end including the upper/lower triple and wheel (but the calipers are the same as the 05/06) it will bolt on to the 03-06.
jfunkRR
04-30-2008 09:23 AM
