Changing tires sizes
Yes, stock is 160 and we've been here before. Bigger tire on a smaller wheel only makes the tire taller. The wheel will still be the same size so the tire will not be wider.
A wider than stock tire (for the rim) will cause the tire to lose its designed profile because it gets pinched in a tad too much. You might have ok contact when leaned way over, but I wouldnt
feel confident on them.
