Carbon Fiber wrap!
Old Dec 25, 2011 | 09:19 PM
donnygeewebb's Avatar
Default Carbon Fiber wrap!
I have been looking at ways that I can make my frame look different on my 2001 F4i. I recently found this carbon fiber wrap on this website --> 3M DI-NOC Carbon Fiber Vinyl
How do you guys think it will hold up on my frame, withstanding heat and all. Does anybody have any experience with this stuff on their bike? Any info would be appreciated! Thanks!
Old May 5, 2012 | 02:43 PM
Risticuss's Avatar
Hey Donny,
I haven't used the 3M stuff, but I recently wrapped my clocks, clock surround panels, and tank trim panels in carbon fibre vinyl and it looked sweet as. The only problem I found was that if you apply heat to the vinyl to make it stretch to difficult shapes when applying it, when it gets hot again (say, leaving it in direct sunlight for 8 hours whilst at work) it can shrink back a bit. That was only at the really tight areas.
It could also melt/sag quite a bit if attached to the frame as I know it can run a little on the warm side.
I'd suggest getting a sample from somewhere, most companies will send you one for free, approx 100mm square and stick it to the frame where it gets warmest and have a look-see what happens.
Hope this helps
Simon
Old May 7, 2012 | 01:50 AM
CJardine's Avatar
Track junkie & modaholic
also attach it to complex curves as well.
Old May 14, 2012 | 11:15 AM
City Bike Racing's Avatar
June 2012 Ride of the Month
Originally Posted by Risticuss
Hey Donny,
Hope this helps
Simon
Pictures
Old May 15, 2012 | 03:35 PM
Risticuss's Avatar
Not the best picture in the world, but should do the job.
Old May 16, 2012 | 08:25 AM
Looks good, nice work.
Old Jun 13, 2012 | 03:55 AM
Edward Tristram's Avatar
Yeah, nice looking mod. Mind giving a brief description of your process?
On a related tip, I've been considering the endeavor of using my existing bodywork, fenders, random parts, etc. as molds over which I can lay carbon fiber and make slightly larger (but hopefully still fit-able) cf replacements that will shed weight, look cool and give me something to do on my goof-around time. Do You Folks think it would unfeasible for any reason? Would the fitment be a major issue even if the size of the cf part was only slightly off? I suppose that would depend on the part I'm replacing, but lets take, for example, two parts: a broad, mostly flat part such as a side fairing and a smaller but more complex part such as a front fender, or the instrument panel cover.
What would be the weight reduction, approximately, of a side fairing made of cf? Would the front fender be such a complex shape that the slight difference in size would make it difficult to fit? I feel like it would be pretty simple to just shift the holes for mounting slightly.
Sorry to totally highjack your thread (mods, I'm 100% cool with pasting this all into a new one if you'd prefer).
Old Jun 21, 2012 | 05:00 PM
boredandstroked's Avatar
The parts will be oversized so in my opinion no good. Cover the stockers in fiberglass to make a mold, then lay carbon fiber inside the fiberglass to make parts. Presto! They are the correct size again.
CBRyder
May 11, 2015 06:31 PM
McBreezyF4i
Aug 7, 2012 08:15 AM
knifemaker87
How-To: Mechanical
97
Jan 23, 2012 12:48 AM
moosestng
Feb 9, 2011 01:12 PM
joelacer
May 7, 2010 11:38 AM
