-1 front help
Old May 20, 2007 | 12:09 PM
larry600's Avatar
Default -1 front help
i'm going to go with a -1 front my ? is did anyone just use the stock chain with all the links and if you did is there room for chain adjustment. i heard the -1 front lets the rear wheel go back a little farther.
Old May 20, 2007 | 12:50 PM
greyd's Avatar
Default RE: -1 front help
Works fine with stock chain unless old and stretched out. There was enough play on mine when I converted.
Old May 21, 2007 | 06:08 PM
Tahoe SC's Avatar
it'll fit fine and you'll be able to adjust it fine. the wear indicator won't be accurate but you'll know when you need a new chain if it's kinking or you find yourself adjusting for the right tension every week.
Nero
F4i - Wanted
Jul 31, 2011 03:22 PM
bammerman
F3 For Sale / Trade
35
Aug 4, 2010 09:40 AM
TMAX
CBR1000F Wanted / Swap
Nov 18, 2009 12:41 PM
Hayden06F4i
May 3, 2008 09:35 PM
