1000F Videos Post up your 1000F related vids here ...
88 CBR1000F Starting Problem
Old Jun 1, 2010 | 10:45 AM
CyberTrip's Avatar
Default 88 CBR1000F Starting Problem
Here's my starting problem. I haven't pulled the alt out yet to get to the starter clutch and damper. I have ordered a used starter clutch on ebay for $20 USD. It is said to be in good condition. We shall see. Anyways, this is me trying to start the bike while it is cold. It sounds like the starter is not spinning as fast as it should or the clutch is not engaged like it should be.
http://www.youtube.com/watch?v=BXsp0Y_lpI4
Old Aug 5, 2010 | 04:23 PM
shakey's Avatar
I take it that you've checked that ALL the connections to the starter motor are tight and not corroded?
Old Aug 6, 2010 | 03:32 PM
shakey's Avatar
Just had another listen to the vid mate! ... It sounds like everythings working normally ... just at about 50% of normal turnover ... which would make me think that either there's a voltage / current leak somewhere in the circuit or your starter motor is FUBAR! .... Did this just suddenly happen, or has it got worse over time? Have you checked ALL the leads for bad contacts etc?
Old Aug 7, 2010 | 02:04 AM
Aussie Johnno's Avatar
Ride of the Year ... Just Ask The Boys
Sorry mate, but sounds just like mine did when the damper went, after i took mine out i could spin the damper by hand.
Not a big job
Aussie Johnno
Old Aug 7, 2010 | 11:50 PM
CyberTrip's Avatar
Ah, sorry I guess I should have updated this thread. The problem ended up being almost no compression on 3 out of 4 cyclinders. I had to adjust the valve clearance. She starts right up now!
vulcanman72002
Aug 28, 2013 05:46 AM
rvnkvn
Nov 26, 2012 01:22 PM
STBrider91
Jun 30, 2009 06:35 PM
elchapor
Mar 10, 2009 08:09 AM
foodman123
Nov 15, 2006 08:30 AM
