Vortex Cut Frame Sliders on my 07 CBR1000RR
ORIGINAL: Starleak
And that neat little trick is.....?
oh yeah, onto the good stuff. Never had to remove the fairings which was ****. He had an array of trimmed old drill bits that he grinded down to specific lengths for each bike. Took off two lower fairing screws and placed the bit into the pocket of the stock bolt and let the fairing rest on the sharp tip. He then put his palm on the fairing and tapped it with this other hand making the mark. Drilled with a pilot drill and then a circle bit with precision it came out perfect. That's about it...I was going to take themoff and figure a way to mark the inside blah blah but his way was much easier..
also, once the hole is drilled you can remove engine bolt and put onthepucks and sliders.
