Turn signals.
RE: Turn signals.
Without Hi-Jacking[sm=guilty.gif]
I was wondering about the Proton Fronts and a Clear Alternatives rear: Question being, the Proton fronts have something internally (from what I read) that eliminates the use of resistors, is that still true with the Clear Alt rear (mine has a fairly quick blink rate/not sure about resistors being installed)?
RE: Turn signals.
ORIGINAL: bboi
Hey actually baxsom the lockhart phillips connect right up to the stock plugs.
as far as the running light
protons allow you to keep the running light or you wire diodes inline on both the turn signal wire and the running light wire and you get both signals and running lights on standard signals
RE: Turn signals.
ORIGINAL: Bloodhound
you can also get a VFX flasher relay
go to www.hooliganbiketech.net and check out the motek signal install. it has a section on the relay as well as keeping the running lights
RE: Turn signals.
ORIGINAL: CBR1000
The resistors for the ClearAlternatives tail light are large. You will have a clean and easy install if you don't use resistors.
Lowridese
05-01-2010 01:12 AM
