Torque specs for rear subframe bolts?
Old Oct 22, 2009 | 04:13 PM
millig67's Avatar
Default Torque specs for rear subframe bolts?
It occurs to me that I should have had the service manual in hand before I started this mod, but....
Does anyone have the torque specs for the rear subframe bolts? And for that matter the bolt that holds the two halves of the subframe together?
I'm assuming my standard practice of "tighten until loose then back off a quarter turn" won't work here.
Old Oct 22, 2009 | 10:23 PM
rellimdekim's Avatar
the manual give torque specs for the bolts and the nuts for the the subframe mounting on the frame as follows:
nuts - 40 ft-lbs
bolts- 32 ft-lbs
and the bolt on the back- 22 ft-lbs
the center plate that holds them together - 9 ft-lbs
hope that helps
Old Oct 23, 2009 | 09:11 AM
millig67's Avatar
Perfect! Thanks.
Old Oct 23, 2009 | 04:45 PM
No problem man
underground-mpyre
Sep 11, 2014 02:58 PM
FosmoenAlex
Jun 11, 2008 07:25 PM
prdtr15
Jun 27, 2007 07:04 PM
Tugzy
Jun 13, 2007 10:44 PM
bluebowtie
Mar 19, 2006 01:11 PM
