Suspension Set-Up ???
get the sag as close as you can
basically the difference between the bike with the wheels off the ground and you sitting on it
average 38-40mm difference on the front
25-30 on the rear
check this post to find out how to take the measurement
http://www.1000rr.net/vb/showthread.php?t=14616
you adjust your preload to get the sag correct
then put zip ties on your forks and rear shock
take a ride
if the zip tie is all the way to the bottom
preload is too soft
it should use most of its travel without bottoming out
as far as rebound and compression
it is all a matter of feel based on the person
oh and btw
i havent read about anyone that was able to get the sag on a stock 1KRR correct for an average weight rider
seriously consider calling dan kyle about some ohlins
25-30 on the rear
take a ride
preload is too soft
oh and btw
try this website: out of all the setting I have tried this is definatly the best. Only small adjustment will have to be made to suit your weight.I have just finished fitting a Jardine rtone racing exhaust. The bike gained 16bhp top end. Sunday 24th I am of for my second track day at Jerez. Can't wait. Also fitted sato rear sets for extra clearence.
Best of luck.
Best of luck.
Sorry forgot to post the website: http://www.sportrider.com/bikes/146_...ettings/#honda
try to get the sag to set first
if you cant get that
then your suspension needs different springs
all the settings in the world will not help springs that arent hard or soft enough to get the sag right
most people who really know the suspension of this bike will tell you that the first thing you need to do is swap the shock and fork springs outs
go to 1000rr.net and do a search on suspension settings
and especially the sportrider ones
honda sets its suspension for the weight of a 150lb rider
that is why oem springs are so soft
put all of your riding gear on when you check the sag
on my oem springs wearing all of my riding gear
full leathers, glovers, back protector, boots and helmet i weigh 205
my front sag at full hard preload was 45mm
that is 10mm too loose
so i got heavier springs
and now it is perfect
ORIGINAL: png13
Best of luck.
Best of luck.
