suspension
RE: suspension
Spring kits are to setup the proper sag on your bike.Depending on your weight with gear ,you may need to get heavier springs or lighter springs to get sag correct..
Once sag is correct the bike will handle totally different.The only way it will handle great out of the box is if you are in the 150lb range.
