suspension set up
Old Apr 26, 2006 | 03:27 AM
blade17fire's Avatar
Default suspension set up
hi guys..can any knowledgeable ones out there advise me on how to set up my front and rear suspension according to my height and weight(track use)?? i'm 1.81m and 70kg..ur advise is greatly appreciated!!
Old Apr 26, 2006 | 07:26 PM
MgA_ODEN's Avatar
Default RE: suspension set up
https://cbrforum.com/m_61651/tm.htm
Old May 1, 2006 | 04:39 PM
thx..
Old May 1, 2006 | 10:13 PM
Socrates's Avatar
I just adjusted mine by winding up both the front and rear preloads and then front and back compression and rebounding dampening. Generally I set everything (in one shot) to 50% between the normally settings and the hardest setting.
Man after that...the bike felt 100% better. Razor sharp and more stable. I am 5"10 and weigh 175lbs..and for me the bike feels waaaay better.
Old May 2, 2006 | 01:31 AM
openclasspro's Avatar
ORIGINAL: Socrates
if i understand you correctly-on comp- you went in to stiffen up/ on rebound did you turn out to speed up or in to slow? on the preloads you went all the way out on the preloads? thanks-phil
Old May 2, 2006 | 02:54 AM
RetroSBK's Avatar
Simple really...
Set the 1G (Sag with rider) to 40mm front and 34mm rear. Swingarm should be pretty much all the way back in the adjusters. Set the swingarm angle to about 14deg, rear shock length should be about 313 - 315. Front should be up about 6.5mm
at 70kg, if you are a decent rider, and run the stock showa fork bits, spring rates would end up around .85km, and rear spring rate is about 8.3.
you of course need to run an ohlins rear to make this work, and I like either the Ohlins of K-tech front kit, the 20mm is way more than pretty much anyone here needs....
This set up is also for the 06, or the 04/05 with the HRC link.
Will
Old May 2, 2006 | 10:08 AM
Socrates's Avatar
Openclass.....for pre-load I did not go all the way out. On the front I went 12 turns out clockwise from the softest setting. For rear pre-load I set it to the 8th position. For compression I turned out (clockwise) to stiffen and same for rebound dampening to speed it up.
I am not expert that's for sure...just tinkering around and found this to work very well for me.
Old May 5, 2006 | 08:34 AM
so the pre load on the front is the hexagon nut at the top of the fork?? am i rite??
Old May 5, 2006 | 06:04 PM
MgA_ODEN's Avatar
ORIGINAL: blade17fire
Yes.
doc6335
Jul 19, 2012 09:05 PM
thatdarkknight
Sep 19, 2006 11:06 PM
PERT1905
Sep 19, 2006 12:14 AM
exup547
Sep 14, 2006 08:10 PM
exup547
Sep 14, 2006 04:40 PM
