slipper clutch?
Old Jan 11, 2009 | 05:55 AM
evablazin's Avatar
Default slipper clutch?
Lookin to do some upgrades to my 06' 1000rr. What exactly does a slipper clutch do? Which is the best for the 06 1k? Thanks
Old Jan 11, 2009 | 09:40 AM
TBagr's Avatar
Default RE: slipper clutch?
the best for the 06 is to trade it in for the 08 that comes with a slipper clutch from the factory.
Old Jan 11, 2009 | 12:46 PM
rellimdekim's Avatar
Go here... https://cbrforum.com/forumid_2/tt.htm ... introduce yourself and your bike....
and for the slipper clutch heres the wiki for you http://en.wikipedia.org/wiki/Slipper_clutch
Old Jan 11, 2009 | 05:16 PM
johnny444's Avatar
From a retail website: "A slipper clutch (also known as a back-torque limiter) is a specialized clutch developed for performance oriented motorcycles to mitigate the effects of engine-braking when riders decelerate as they enter corners. The engine braking forces in conventional clutches will normally be transmitted back along the drivetrain,causing the rear wheel to hop, chatter or lose traction.
[ul][*]Designed to partially disengage or "slip" when the rear wheel tries to drive the engine faster than it would run under its own power. This is especially noted on larger displacement four-stroke engines, which have greater engine braking than their two-stroke or smaller displacement counterparts. [*]Eliminates this extra loading on the rear suspension giving riders a more predictable ride and minimize the risk of over-reving the engine during downshifts. [*]Can also prevent a catastrophic rear wheel lockup in case of engine seizure or transmission failure." [/ul]
STM and Yoyodyne are the two most well known manufacturers of slipper clutches. A quick googling shows that they are available for between $750-$820 before tax and shipping.
Old Jan 12, 2009 | 10:40 PM
SD2007's Avatar
Veryfew streetriders actuallyneed a slipper clutch, odds are you'll be fine without it. If you find that your rear tire is moving around on downshifts, then it may help.
Old Jan 13, 2009 | 12:32 AM
CBRCRF's Avatar
Are you going to be tracking the bike? If not then dont bother. Just blip the throttle on down shifts.
Old Jan 14, 2009 | 10:06 AM
some guy #2's Avatar
If you have money to burn then go for it but there are other mods that will be more helpful to you. I will admit having a slipper would make coming into a turn much easier.
Old Jan 18, 2009 | 11:10 AM
Rod38um's Avatar
I'd like to have one, I tend to down shift hard when I'm feeling aggressive. Sometimes it gets a lil squirlly feeling especially if I'm in a turn, even a slight one. One of these days I'll upgrade to a newer model and see if it helps....
Old Mar 16, 2009 | 08:34 PM
Jtrain's Avatar
Do you guys not rev match? I rev match every shift.. does anyone else?
Old Mar 31, 2009 | 11:29 PM
ichlgo's Avatar
I try to. Its a good habit.
