Removing The Passenger Rear Sets
Old Aug 14, 2007 | 10:17 PM
JokeRR's Avatar
Default Removing The Passenger Rear Sets
I don't know if it's been covered here...if so, feel free to link any prior forum activity on the subject. I have a 2004 1000RR and want to remove the passenger rear sets. But part of the rightside bracket is a tapped mount for the top heat shield bolt. Anybody know if there's a pre-fab aftermarket mount you can buy, or am I just looking at custom machining?
Thanks
The FNG (Fuggin New Guy)
Old Aug 14, 2007 | 10:50 PM
bornluckee13's Avatar
Default RE: Removing The Passenger Rear Sets
No, your gonna have to make on. It's not that hard really, just get a small strip of aluminum, available at lowe's, bend, drill, and tap or use a nut. OR... you could do what I did and just scrap the heat shield all together....looks pretty tuff ! Good luck to ya either way man!
Old Aug 15, 2007 | 11:57 AM
JokeRR's Avatar
Got it. Thanks for the feedback...well said.
Peace!
Old Aug 15, 2007 | 12:58 PM
mihomie's Avatar
just do what i did and buy a rearset off ebay. then cut off the piece that attaches the heat sheild. i cut the other peg leg also to keep the little rear resovior guard in place. i also painted them flat balck so they match the frame. easiest way i could think of to keep the sheild on. if i knew how to attach a pic i would
Old Aug 16, 2007 | 12:51 PM
baxsom's Avatar
mrgrn of 1000rr.net makes a carbon fiber bracket to do just what you are looking for
or go to www.hooliganbiketech.net and look up the brake upgrade how to. It will show you how to make the bracket yourself
Old Nov 4, 2007 | 02:53 PM
GBster's Avatar
Hey Fuggin New Guy, I sent you a PM but not sure it went through.
CCs down and thought you'd like to continue on the Activcard mod if You are You, I'm still me.
And if You aint You, sorry for the hijack JokeRR.
Old Nov 4, 2007 | 06:54 PM
mihomie's Avatar
take the peg and cut it or buy an spare off ebay, or from someone else. paint it flat black and call it a day.
[IMG]local://upfiles/17936/3B16730B143F4DA2A046661FEF892537.jpg[/IMG]
Travis_
Nov 5, 2013 08:32 PM
Jeffcbr600f2
F3 Wanted
Jul 18, 2012 07:58 AM
cyber00677
Feb 2, 2008 11:30 AM
brancart1
TRG Coating
Jan 5, 2006 03:26 PM
