rear tailights LED issues
Old Jan 2, 2007 | 05:06 PM
RRorXX's Avatar
Default rear tailights LED issues
Hey RR lovers check this out, have any of you ever had this issue I installed a rear taiL light LED, blow a fuse and then not have one of trn signals not work, Itested the tail light and both the right and left turn signalluminates ok, but now the right turn signaldoes not work, the lt is ok. same results after changing fuses. I was thinking it could be the turn signal relay switch. So before dismantle my in an effort to find this short, does ant one have any suggestions?
Thanks
Dor, Hot rr
Old Jan 2, 2007 | 08:08 PM
XLR8's Avatar
Default RE: rear tailights LED issues
I guessing you are talking about a Clear Alt tail light? I did my install about 2 months ago and have had no issues. The only suggestion I have is to take a good look at the web-site below and double check all your wiring. EZ to make a mistake. If you start looking for your relay it's behind the left mid-faring.
http://hooliganbiketech.dynup.net
Good luck
cbr600f2rr
Sep 30, 2011 01:05 PM
CBRInfantry
Feb 18, 2011 05:05 PM
CatDaddy512
May 14, 2010 06:51 PM
cbreric
Aug 15, 2009 08:07 PM
sc0re2
Dec 11, 2007 05:01 PM
