oem harness stuff-couplers,terminals etc
Old Aug 30, 2009 | 06:39 PM
zero1's Avatar
Default oem harness stuff-couplers,terminals etc
does anyone know of a source for oem harness terminals, couplers etc. i have searched this forum and been to the dealer without much success. honda hasnt made it easy as they dont give these components part numbers, at least on the fiche i have seen. the k&l catalog has many options. i am just not sure of which one, or if there is one. in particular i would like to match the 4pin(male/black) from the tail/stop and the 3pin(male/white) from the lisc/left/right turn signal so that my fender eliminator will install so-super-sweetly. i could solder, splice, hack , slash. have done so in the past and may have to again. this time i would prefer not to.
cheers
Old Sep 10, 2009 | 09:03 PM
zero1's Avatar
i have some progress to report. the sub-harness for the plate/turn signal is honda part number 32108-mfl-000 my dealer had it listed for $17.64 and it was back-ordered. i found one on e-bay for $19.99 shipped. recieved it in a day as the guy is only one state away. this still leaves me with out the brake/tail light connector. so far, it seems i will have to buy the whole brake/tail light just to get the connector. maybe someone has a bad light with a good connector? i wish
Old Sep 11, 2009 | 03:01 PM
johnnyx's Avatar
That's a rough one. Given your prowess, I'd personally reccomend just buying your own aftermarket from Digikey or wherever. Just buy a bunch of coupler connectors that have the number of pins and gauges you need.
Panda2k1F4i
Jul 9, 2010 10:39 PM
guy022077
Jul 7, 2008 05:34 PM
