hotbodies undertail
Old Jan 4, 2007 | 08:39 PM
ALVINCOBRA_94's Avatar
Default hotbodies undertail
If you have one please advise, i just instaled mine and love the sound but the red light on the gauge cluster is blinking, why and how do i fix it?
And what are your thoughts about the power commander , do i need one? I am not looking for more power just the look & sound.
Old Jan 5, 2007 | 12:36 PM
bboi's Avatar
Default RE: hotbodies undertail
I have the hotbodies on my 04 right now. I got the power commander because the hotbodies guys recomend it, and also it was spittin an backfiring alil on my bike. I mean the blue flame looked cool but Im sure it wasnt too good for the bike lol
Old Jan 5, 2007 | 03:56 PM
Have you had any problems with the heat shield tape? & how did you get the light to stop blinking?
Old Jan 5, 2007 | 06:36 PM
bboi's Avatar
Ive had one melt on me because of the bolt that holds the canister up came loose one day an the can fell on the plastic. hotbodies sent me a new one and havent had any problems since. I put double heat sheild thou. There was no light flashing on my bike tho.
Old Jan 5, 2007 | 07:39 PM
errick_morris's Avatar
I have one on my 05 1000 RR and I can't ever remember the red light coming on in my cluster. I also had the Power Commander installed at the same time so it could be a fuel/air mixture issue. As far as the off throttle poppin, most aftermarket exhaust do it, some even more than others. Don't know how to tell you to fix that completely....A good custom map will definitely help. I have a 2 Bros full system map and it has a perfect fuel/air ratio.
Do add extra heat shielding. Get if from your local shop. There are some places right behind the seat where the tailsection begins that may not be protected by the pipe. Other than that, keep an eye on the undertail plastic, in the summertime, it may warp into a U-shape instead of being flat at the taillight. So make sure to coat the entire undertail plastic with heat shield. (trial & error)
Old Jan 5, 2007 | 10:10 PM
Would the removing of the exaust valve cause the light to come on?
Old Jan 19, 2007 | 02:24 AM
zerochickenstrips's Avatar
You can't remove the entire exhaust valve actuator assembly (the box behind the battery on '06s. Just remove the cables from the pulley and leave the assembly plugged in. And yes removing it will throw an FI code on the MIL.
Old Jan 22, 2007 | 06:57 PM
fisk_e's Avatar
hey, i got the same color and year 1k and was thinkin about that exhaust, can you post any pics?
Old Mar 6, 2007 | 02:23 AM
cocoscbr's Avatar
i got a rs-5 full carbon yoshi. i completely took the butterfly assembly out.i disconected the cables and tucked them into the bike.and my Fi light or the red OIL pressure light didn't come on
Checkered Past
Aug 15, 2011 12:19 PM
undagroundrican
F4i - Wanted
Jun 7, 2011 09:47 PM
Will1000RR
May 23, 2008 10:05 AM
adam24
Apr 4, 2007 09:41 PM
Bunz15
Feb 19, 2006 02:33 AM
