HELP gas tank hose mystery
Old 08-25-2007 | 10:36 PM
mihomie's Avatar
Default HELP gas tank hose mystery
I just installed a PCIII on my 06 and have a hose I can not find a fitting for. On the bottom of the tank there is a 'T' fitting one end has a hose that has a white nipple that I can not figure out what it connects to. I looked everywhere for a mating piece no luck.
When I went to pull p th etank there was a little resistance and then it just popped up.
HELP![/align]
Old 08-25-2007 | 10:41 PM
1fasthonda's Avatar
Default RE: HELP gas tank hose mystery
The are two hoses that connect to the T fitting. Then there should be a long hose comming off the T. This hose is a vent hose that runs down the left side og the bike.
Old 08-26-2007 | 09:14 AM
bornluckee13's Avatar
It should lace in right next to your clutch, right under the clutch line... I think... Hmmmmmmm
Old 08-27-2007 | 11:03 AM
mihomie's Avatar
whew
thanks , i was a bit nervous. the bike does seem to have more midrange punch with the pc and it cleaned up the low rpm stumble quite a bit.
andrewds96f3
09-04-2012 03:38 PM
Captlombardi
06-22-2012 08:44 PM
MikeInCtown
06-02-2011 10:55 PM
Babyc1999
07-12-2007 06:41 AM
israel
02-15-2007 04:42 AM
